Lian Li PC-V358 Review - Cooling Performance
Due to the fact our usual micro-ATX cooler won't fit in the Lian Li PC-V358, we clearly weren't able to add our results to our usual micro-ATX case graphs. However, we did have another way of comparing it to a bunch of other small cases, which was to use our mini-ITX test gear that uses a low profile cooler. This means that comparisons can only be made against the results in the graphs - not with any other micro-ATX case results.
Our test kit includes:
  • CPU: Intel Core i5-2500K overclocked to 4.3GHz using a vcore of 1.3V.
  • Graphics card: GeForce GTX 570 1.3GB
  • Motherboard: Asus P8Z77-I Deluxe
  • RAM: 4GB Kingston DDR3 1600MHz memory
  • PSU: Enermax Eco 82+ 620W PSU
  • CPU cooler: Zalman CNPS 8900 low-profile cooler
The graphics card fan was locked at 70 per cent speed and the system was loaded using Prime95 and Unigene's Heaven benchmark. We used Realtemp and GPU-Z to monitor the temperatures, taking the maximum values when the readings had plateaued.
Case performance - CPU Delta T
Arranged by CPU Delta T
  • Silverstone Sugo SG08 (High Speed)
  • BitFenix Prodigy
  • Silverstone Sugo SG08 (Low Speed)
  • Silverstone FT03-Mini
  • Fractal Design Node 304 (High Speed)
  • Cooler Master Elite 130 Advanced
  • Lian Li PC-TU200
  • Lian Li Lian Li PC-Q28
  • Lian Li PC-V358
  • EVGA Hadron Air
  • BitFenix Phenom
  • Cooler Master Elite 120 Advanced
  • Fractal Design Node 304 (Low Speed)
    • 41
    • 53
    • 43
    • 48
    • 44
    • 56
    • 48
    • 58
    • 49
    • 47
    • 49
    • 55
    • 49
    • 63
    • 53
    • 59
    • 54
    • 53
    • 54
    • 54
    • 54
    • 57
    • 55
    • 56
    • 59
    • 49
20
30
40
50
60
70
°C, lower is better
  • CPU delta T
  • GPU delta T
Case performance - GPU Delta T
Arranged by GPU Delta T
  • BitFenix Prodigy
  • Fractal Design Node 304 (LowSpeed)
  • Lian Li PC-V358
  • EVGA Hadron Air
  • BitFenix Phenom
  • Lian Li PC-Q28
  • Lian Li PC-TU200
    • 49
    • 47
    • 43
    • 48
    • 59
    • 49
    • 41
    • 53
    • 54
    • 53
    • 54
    • 54
    • 49
    • 55
    • 44
    • 56
    • 55
    • 56
    • 54
    • 57
    • 48
    • 58
    • 53
    • 59
    • 49
    • 63
20
30
40
50
60
70
°C, lower is better
  • CPU delta T
  • GPU delta T
null
